Home > Technical (L405) > Driver's Seat Rubbing centre console
Heyloft
2019 Range Rover Vogue SE SDV8 Carpathian Grey
Didn't need a laser for that one. Shocked
The rear of the console is 10mm nearer the righthand B pillar.
Wonder if it can be re-sighted ? Anyone got a copy of the Topix diagram for removing the centre console? Wot's that in old money
Post #545235 26th Feb 2020 5:52pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I would use the tried and tested centre console re-alignment tool...
Lump hammer!
Post #545236 26th Feb 2020 5:55pm
http://www.fullfatrr.com/gallery/albums/us...%20AND.pdf
Thumbs Up ... - .- -.
Post #545239 26th Feb 2020 5:59pm
Heyloft
Lump hammer!
ER ! NO its mint Shocked
Thanks Stan, that just shows how to remove the upper console, its the lower I need to see, so that I can determine if there is ability to adjust it. Wot's that in old money
Post #545240 26th Feb 2020 6:12pm
Rob99
It's under warranty.
Tell the dealer of the measurement discrepancy you found and let them sort it out. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #545258 26th Feb 2020 8:12pm
Heyloft
Rob99
When it was in last week and it looked like a dodgy drivers seat the Dealer was very much ‘well it was manufactured like that’.. they didn’t even take any measurements.
I took it in for the following (2 weeks after I bought it from them)
Seat rubbing
Stop/start not working
Tv picture and sound out of sync
Gearbox holding gear too long
Rattle creak from roof (sounds like pan roof rub on bodywork)
They had it for 4 days and managed to fix... drum roll... one of them, the gearbox issue.
The other faults still exist and it’s going back 10th March for the pan glass roof to be refitted. I’ll give them one more go at the other faults Neutral Wot's that in old money
Post #545277 26th Feb 2020 10:12pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Maybe there is room to push the armrest towards the seat - there is an allen screw, but to get to it involves removing the back panel of the seat...
http://www.fullfatrr.com/gallery/albums/us...rmrest.pdf
And honestly, I don't think the console can be/should be repositioned...
Post #545293 27th Feb 2020 6:46am
Heyloft
Adara,
I’ll take a look at that, but it doesn’t alter the fact that the console is in the wrong position Big Cry Wot's that in old money
Post #545295 27th Feb 2020 7:26am
adara
Is it? In the wrong position? Can it even be mounted wrong? Is the distance to the B pillars different?
Post #545324 27th Feb 2020 12:44pm
Heyloft
Yes 10mm nearer the driver’s side B pillar Wot's that in old money
Post #545331 27th Feb 2020 1:31pm
