![]() | Home > Maintenance & Mods (L322) > Brake pedal travel |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
Mine is about the same. I replaced a seized caliper today and bled the brakes. Took it for a drive and the pedal is about halfway before it starts to brake. 2011 4.4tdv8 Vogue
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Hi Gaz, thanks for taking the time to respond I was hoping with over 80 views to get a better response but there you go. I will let you know what I find out later this week once the garage has finished with it |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Mine has a bit of travel before it bites |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
My Td6 has the same amount of brake travel before it bites, have replaced both rear calipers as they were sticking.
Gentlemen, many thanks for taking the time to respond. Sounds like the pedal travel is normal from what I'm reading. I'll post back here what the garage say after they have looked at it tomorrow, although I suspect it's going to be one of those "couldn't find a fault, and here is your invoice" conversations. |
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 54 ![]() ![]() ![]() |
just checked mine and you can feel brakes starting too apply after about a inch of travel
Hi Jordon, that's about what I would expect to be honest, in my case it's almost half way before you feel the brakes apply. My Freelander 2 on the otherhand has exceptional brakes, so much so that I headbutted the sun visor when I jumped in it to move it out of the drive the other day. I had become used to having to press the FFRR pedal so far before I had any brakes applying. |
Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 22 ![]() ![]() ![]() |
Mine (4.4 tdv8) travels about half way befor starting to bite ,which is about the same as the two previous ones, 4.4 petrol & 3.6 tdv8 being a ‘ off road ‘ vehicle , would you want breaks that would just lockup at the slightest sign of anything remotely slippy? I know I wouldn’t |
Off road?? I thought they were for seeing over the hedges. Doh! 2011 4.4tdv8 Vogue
Collected car from the garage this afternoon Turned out there was trapped air in the system that the computer bleeding process couldn’t shift so they went back to the old fashioned method and after a litre of brake fluid being pushed through the system all the air was removed. Brakes are 100% better, when I press the pedal now the brakes begin to bite after around an inch of travel, I’m now able to brake progressively. |
glad you got it sorted
Yes it does make you wonder, the responses didn’t really confirm how the pedal should feel as there seemed to be a mixture of answers. Now having mine fixed I can say that it feels as I would expect any cars brakes to feel especially modern ones with ABS etc. Perhaps a lot of people don’t bother having the brake fluid changed as part of the service schedule causing it to become less effective. |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I agree I was almost thinking mine was abnormal with little travel 😂
