Home > Technical (L405) > Keyless locking opens and unlocks but temperamental locking
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
16MY L405. Keyless entry works fine on all doors. Locking seems more temperamental. Drivers door v rarely works. Driver side rear, occasionally. Both Passenger sides work ok. I’ve replaced battery in keyFOB no difference. Other fob similar.
Looks like into the Dealer for check? Or Anything I can try?
Ta Thumbs Up
Post #544826 22nd Feb 2020 6:18pm
Vogue
I also had similar problems, however when using keyless locking make sure the key is within a couple of feet of the door and also make sure the key fob is in your pocket on its own - a bundle of other keys and / or change totally destroys the signal and caused intermittent locking 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #544831 22nd Feb 2020 7:21pm
stenh02
Thanks, yes did wonder about interference but as it unlocks door no issues couldn’t really explain it. But I have tried it with key Fob in my other hand and same hand that does the locking, but still no improvement.
Post #544868 23rd Feb 2020 7:33am
Beach
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Barolo Black
I also get this on my 16 plate, opens fine but rarely locks. As above tried with key on its own in my hand and still issues
Post #544882 23rd Feb 2020 10:22am
esp22
Did you find a solution for this?
Post #707673 27th Dec 2024 1:08pm
I turned mine off as soon as I got the car. Couldn't tell you if it works, prefer the push of a button to definitely lock the car...... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #707837 29th Dec 2024 7:37pm
