![]() | Home > LPG > 4.2 owners with lpg quick question? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
Must have a fuel return.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
The fuel return is what they want it back for - but out of curiosity why is an emulator bad? is it a pressure in tank issue? Current stable:
Your fuel pressure is just one of the parameters that gets fed to the ecu to determine injection timing if its wrong by a considerable amount, it will be without a fuel return fitted, your engine will not run properly and you will end up running rich or lean or just end up chasing your tail to resolve, you MUST have a fuel return fitted with an in line orifice to replicate how the fuel pressure would be if running on petrol.
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
My advice don't do the conversion, mine eat itself to death, the vale seats are just too soft even with flash lube after 60k on gas one dead engine. |
What did you do with it lighthouse? As far as I was aware when the valve seats go it just makes it had to start and run rough until you to temperature where it then stabilises?
As described is how it is when it starts to happens, as they then wear more the start to leave gaps all the time get air into the cyclinders and causes misfires and then it gets to the point where the compression is so low the car is useless. |
