Home > General > storms and floods.. do you drive through them?
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
So with the l322 having a wading depth of 700mm and the 405 900mm.
with all the floods around during and after the storms do people drive through them? I mean is there realy any floods big enough to stop the range rover?
I havnt yet encountred any bad flooding local to me.. Only because i havnt needed to venture out but i am curiuos if i see a load of traffic driving around a big ass flood do i just gun hoe it right on through there? Ok i really mean drive senisibly through there... Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #544141 16th Feb 2020 8:57pm
DrRob
Nope. It ain’t worth it and only ever if it was a dire emergency.
It takes Censored all water depth to escalate into a deadly scenario.
Puddles are ok Thumbs Up Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #544143 16th Feb 2020 9:13pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Just had this situation yesterday, driving from Bolventor (Jamaica Inn, Bodmin Moor) along their Valley to Goliaths Falls.
I went through the first flood, in a dip I knew well and it came half way up the wheels. About 1/2 a mile in the river then merged with the road and I couldn’t see the exit to the floodwater back on to dry road. Unless you know the depth, you can see the exit, there’s no flowing water and you know that there are no underwater obstructions, you can just be driving blind in a £100,000 gamble Shocked For any serious flood, unless there’s a life or death reason, it’s just not worth it and there’s usually another way around Thumbs Up
Post #544144 16th Feb 2020 9:23pm
dazza1983
Surely if the l322 can wade to 700mm then any flooded road etc thats not 700mm would be fine? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #544158 17th Feb 2020 9:47am
Red Merle
Without wading it first, how do you know it’s 700mm?
How do you know if there isn’t an underwater obstruction, or a bridge that’s damaged, or even missing, under the floodwaters? Had someone abandoned their bike under the floodwater? Were there roadworks in the road before it was flooded?
What if the water is flowing across the road?
Can you even see a clear exit, with no stranded cars blocking the road?
Post #544165 17th Feb 2020 10:17am
...and silly as it sounds it can be difficult to know exactly where the road goes and you don't want to be putting a wheel on a submerged verge (or worse). Mike - MPx
Post #544170 17th Feb 2020 10:33am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
This was in 2014. A member on here
Post #544184 17th Feb 2020 11:48am
dazza1983
Sorry i should have been cleare on my 1st post lol..
Im talking about roads that you know and areas you know well.. For instance if any of the roaads round be me flood theres no way in heel they would reach 700mm lol,
Whats a kerb 400mm at best? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #544187 17th Feb 2020 12:09pm
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
that's a great vid Paul! Bow down
Knowledge of the road surface of course is key and if unlucky you may get stuck in a hole or collapsed piece of road, but the Rangie can cope with a deep flood no bother in my experience. I carry a long stick which I can use to gauge the depth if required.
I once undertook an off-road test with LR in Germany where we drove rangies around our tank driving range. One part of the Course was to drive along a tank ditch/Channel where the water came up to the top of the wheel arches and nearly to the bonnet. We made it through several times with water flowing over the bonnet and the roof Shocked
(We did get a Censored from the LR people for going too fast, but then passed him next time round when he had stalled it in the middle of the same ditch by going too slowly!! Rolling with laughter)
So the advice seems avoid unknown roads; gauge if you can; keep a decent speed up. oh and drive on the crown (middle) of the road if poss!
Post #544188 17th Feb 2020 12:11pm
dazza1983
Thats quite cool, wonder how deep that was? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #544190 17th Feb 2020 12:12pm
Mutters_Mate
Drain covers and manhole covers have a habit of being pushed up by water pressure. Don't want to put a wheel down one of those. I wouldn't put my old D1, that had a raised air intake and raised breathers, through unless I checked first. One washed away culvert and game over!
Also consider any properties nearby, you'll create a bow wave that will push water in all directions and may even flood a home that so far has survived. Mutters_Mate (Mark C)
2002 TD6 SE
Post #544192 17th Feb 2020 12:17pm
PaulTyrer
From memory, it was a Fullfatrr member from the Wraysbury area. There is a comment on the youtube site that mentions 4 feet!!
Post #544193 17th Feb 2020 12:32pm
Philip
Where’s that clip of the Discovery 5 with a Discovery II on a trailer, both being washed away?
Post #544194 17th Feb 2020 12:33pm
Red Merle
I was looking for that earlier. As soon as the D5 started to float, it was off with the force of the river.
Post #544220 17th Feb 2020 5:05pm
Red Merle
What happens when you meet a nutter coming the other way, one that hits you with an engine drowning bow wave in the deepest section? How do you know where the ditches are if you need to get past a flooded and abandoned car or van? Without being able to see the other end and you hit an obstruction, would you reverse all the way back, or attempt a 3 point point and hope you don’t find a drainage ditch?
Post #544222 17th Feb 2020 5:11pm
