I had a local garage install the new pipe and the new complete rear bar assembly, but I'm still getting the same error messages and creaking from the suspension. They bled the bars front and back, but the error kept appearing.
Scanning with my IID Tool, the most common is "C1119-09 ( AF ) Hydraulic pressure - General failure information", which accompanies either the red or amber warning on the dash.
I've also had...
C1B11-62 ( 28 ) Pressure control valve - Algorithm based failure
C1B11-92 ( 2C ) Pressure control valve - Component failure
C104C-94 ( 28 ) Rear axle piston - Pressure regulating valve - Component failure
C104A-94 ( 28 ) Front axle piston - Pressure regulating valve - Component failure
Given the various codes popping up, they all look to me like an issue with pressure in the system, so I checked the fluid level. The cap was wet, but I couldn't tell if that was just a bit of spillage from when they topped it up. With the engine off, the fluid was higher than the "max" level, but with the engine running, it drops very low — I'm assuming there's still air in the system.
Question for the OP — what procedure did you follow after replacing the pipes? Did you have access to the Land Rover bleeding tools?
