![]() | Home > Technical (L322) > Brake issues l322 2004 td6 |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
I’d be looking To the ABS PUMP or a kink in the rear pipes, have you taken off the rear flexi pipes to see if anything drips out? 2004 Autobiography TD6 Java Black |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
Those symptoms do sound a bizarre combination !
Sx200 Member Since: 09 Nov 2018 Location: Gold Coast Posts: 5 ![]() ![]() ![]() |
Thanks for the comments.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Could be the master is faulty, even second hand parts sold have to work if you bought it as working, if you bought it from a reputable sellers ask for a swap |
The master cylinder is a new one, the ABS is second hand. |
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 ![]() ![]() |
I would suggest that you change all four of the rubber flexible brake hoses.
