Home > Range Rover Classic > fuel lines
ajac8
fuel lines
93 EFi. My fuel lines are beginning to look a bit tired and I can't remove the current fuel filter - the nuts are rounded and totally stuck. I'm looking to replace both the flow and return lines complete with rubber. Its obvious that rigid replacement is probably impossible with our the body off. The only issue I can see is connecting the new rubber to the steel vertical lines in the engine bay. Theres are the ones wrapped in heat shield and look in very good condition. Has anyone else done this as a complete job and removed all steel lines including these wrapped in heat shield?
Could I just remove all steel lines and connect rubber to rubber at both the tank and engine ends with inserts and jubilee clips? Does anyone know what is the ID of the existing rubber at the tank and engine ends are?
At least then I can insert a new fuel filter in line. Anything else I should be worried about?
Cheers Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #541996 26th Jan 2020 7:36pm
