Home > Technical (L322) > No heat after radiator change FIXED
Muzzychris
Hello all, I have replaced the radiator again today due to a leak, after re fitting and following bleed procedure I think I must have an air lock as I am getting no heat through the fans. Car is not overheating and have ran upto temp. Letting it cool for a few hours now. Is there any tricks to clear this (guessing airlock)
Thanks!
Post #541059 19th Jan 2020 1:54pm
Dolphinboy
Which engine!
Post #541061 19th Jan 2020 2:33pm
Muzzychris
Sorry! 4.4 M62 v8 2004
Post #541062 19th Jan 2020 2:36pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Heater set to max both sides ?
Post #541103 19th Jan 2020 9:07pm
Dolphinboy
Try removing and re-fitting the pollen filter (sits just in front of and below the windscreen at the rear of the engine bay), I had the Same as you and this seemed to fix it. Probably hadn’t been seated probably?
Post #541121 19th Jan 2020 11:35pm
Muzzychris
Thank you Dolphinboy! All sorted and have heat again!
Post #541136 20th Jan 2020 7:34am
Dolphinboy
What was the fix?
Post #541143 20th Jan 2020 9:05am
Muzzychris
I tried the pollen filter with no luck, I just let it idle for about 30 minutes, still nothing. Then I gave it some big revs 3 or 4 times with the expansion cap off and that seemed to push the air through as I now have heat Smile
Post #541168 20th Jan 2020 11:53am
Dolphinboy
Well done. The other cause I should have mentioned was the flaps sticking. Glad you got a result! Thumbs Up
Post #541172 20th Jan 2020 12:24pm
