Home > General > How reliable has your FFRR been?
dan_uk_1984
speedymarktd6 wrote:
so in theory you shouldnt have a problem Thumbs Up
Unless I wear it out!
I remember on another forum discussing the failure of the deadbolt locks (superlocking) on the P38.... everyone came to the conclusion that you shouldnt superlock the car because it would wear the lock motors out and they might fail after a few years! Confused It's there to be used - just not abused!
Post #4876 10th Apr 2009 9:16pm
Mine's had the usual small niggles i.e.; parking sensors sulking for a day and the rear wash jet declaring independence, the only real problem is my rear brake callipers seizing within six weeks of each other and I'll never know if that is just bad luck the fact that I drive off road and tow heavy trailers or poor quality, but what I have learnt is that the stealers are a bit , well lets just say they should not be allowed sharp objects Rolling with laughter 2008 MY Supercharged
Post #4878 11th Apr 2009 9:36am
Well do not want to tempt fate here , but for the last 2 years i have not had any major problems apart from the common suspension fault.
The first year it was in and out of the Stealers about a dozen times for allsorts of stupid faults mainly re-programming issue's .
Other than that Nowt so far .
JUST PUT THE KISS OF DEATH ON IT NOW ............. Whistle Whistle Whistle
Post #4880 11th Apr 2009 9:57am
speedymarktd6
so analizing all the info on here if we all put our FFRR in our garage with cotton wool around it and never use it theres a good chance we wont have any more problems and land rover will be no 1 for reliability with zero faults Rolling with laughter Rolling with laughter Rolling with laughter onto no6 Range Rover
Everyone needs a hobby
Post #4883 11th Apr 2009 12:13pm
Suppose , but a car costing 74k should not have had so many faults in the first instance .............
Post #4884 11th Apr 2009 12:19pm
wardpg
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Had mine 8 months now TDV8 not been back t0 the dealers for any problems at all, brilliant car. Mind you now I have said that probably get a fault tomorrow !!
Post #4889 11th Apr 2009 5:09pm
dantheman
Oh dear... Somebody had to say f Censored ing fault didn't they... Rolling Eyes
My dvr seat electrics have just decided to knock off for Easter - B Censored rds!!! At least it'll give me something to do over the holiday though eh?!?
The joys of ownership indeed - my arse...
Post #4892 11th Apr 2009 6:47pm
The Flying Scot
Scotland 2012 Range Rover Westminster 4.4 V8 Fuji White
Since buying mine 2 years ago, I've had....
Lower suspension arm replaced
Diff replaced ( recall)
Air Suspension ECU replaced
Passenger cup holder replaced ( spring broke..a common fault..I'm told)
Centre Console cup holder replaced (spring again !!!)
And today it was towed away as the font n/s track rod end ball joint has gone and the Airbag SRS light is on!!
Now I've had Landrover for the last 12 years and this is the most unreliable vehicle yet. Maybe I got a bad one and its beginning to drive me mad, but I still love the car.
Thankfully the AA warranty I took out had covered most of these faults. 2011 Range Rover TDV8 4.4 Vogue SE
2007 Range Rover TDV8 Vogue (Sold)
2004 Range Rover Vogue TD6 (Sold)
Post #4934 14th Apr 2009 10:27am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Bought mine at 14 months old. Day after purchase had DVD player replaced as would not communicate with head unit (garage thought it would be a faulty fibre cable at first).
Also had front passanger seatbelt + unit replaced simply because the small plastic stop (prevents buckle dropping too far down belt when not worn) had been broken off at some stage, a couple of pence item, which I thought would just involve them pinning a new one on. However, the part is not available individually!! Seems ridiculous to scrap a whole seatbelt. ( Under warranty of course anyway ). I've also got the occassional steering column powering to my knees syndrome which only ever occurs just after I have memorised a new seat position etc. Garage aware of it though. Even with these few problems, it's still the car that's lived up to my expectations ever since I bought it and it really does have a 'feel good' factor when you get into it. Brilliant! Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #5119 22nd Apr 2009 8:07am
