Home > Technical (L322) > Deadlocked? Or broken handle cable? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 873 |
The info. in this post might help?
9th Jan 2020 9:15am |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
Could be that all the locks have frozen if it's really cold.
9th Jan 2020 9:18am |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
Yes, I have seen Heppsen's post (and in some form of Karma I had posted a reply to the OP's topic in that thread!) but I can't can't get any door open as it stands.
9th Jan 2020 9:24am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2660 |
Long shot, but the car might have global open working, if you keep your finger on unlock, windows might come down, that way at least you can enter the vehicle, get the bonnet open and go through a battery disconnect procedure to try and reset modules. Do the easy stuff first |
9th Jan 2020 10:11am |
Hi Mr Tee, bonnet open and battery on charge in-situ.
9th Jan 2020 10:21am |
Yup it's that simple mate, nae idea the length of time to hold them together though, IIRC 10 seconds ish.
9th Jan 2020 11:37am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
You could always try a hair dryer or hot air gun around the drivers door seal and lock to see if it will open after thawing. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Im pretty sure on the early models ONLY the drivers door lock will open with the key! It does NOT work the central locking sir... Its a mechanical lock/unlock only...
9th Jan 2020 11:57am |
"Im pretty sure on the early models ONLY the drivers door lock will open with the key! It does NOT work the central locking sir... Its a mechanical lock/unlock only... "
9th Jan 2020 12:51pm |
Back home after work. Door not frozen. Key moves the lock barrel and the button moves up and down. That seems to work.
9th Jan 2020 4:41pm |
Long shot but have you checked the door harness connector located between the door and body is pressed fully home / not wet or corroded?
9th Jan 2020 5:52pm |
No not checked the harness but battery out now and I should be able to open the drivers door without electricity shouldn't I?
9th Jan 2020 6:12pm |
The release actuator is behind a small removable cover incorporated in the lower part of the upper tailgate internal trim
9th Jan 2020 7:56pm |
Do you have AA cover?They are pretty good at gaining access to locked cars...
9th Jan 2020 11:36pm |
