Home > Maintenance & Mods (L322) > Weird noise - Fans? Whirring noise...
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Hi,
The RR has developed a strange noise - only just audible but there and enough to make me wonder what it is. When pulling away I get a kind of fan 'whirring' noise coming from the gear stick - it only happens when I apply pressure to the accelerator (at tickover no noise at all).
It's not the gearbox (replaced last year) - could it be the air conditioning/fans in there? Anyone else had anything similar?
Cheers Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
Post #57038 28th Mar 2011 5:22am
dan_uk_1984
The fans are quite far forward - under the wipers. Mine has a slight hi-pitched whirr under breaking due to the fan bearing being slightly worn.
Have you tried turning the fan right off to see if it still does it?
When the PCV system is on its way out it can make a low howl sort of like a really low whistle. Have you changed your PCV hoses?
Post #57041 28th Mar 2011 7:30am
Superspoons
Yes, replaced the PCV hoses last year - but with the 'genuine' BMW/LR ones from LR...I guess they could of broken down again. Will check though, cheers. Gavin
Post #57214 28th Mar 2011 7:44pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Not the whistling noise of the little cooling PC-fan on the bottom of the electronic black box ? It sounds like the whistle noise is inside the car, drivers footwell ..but if you get out of the car and press your ear against the black box --ít´s from here... XJC, RRV8, Series1 86 and 107% of real pleasure
Post #57978 31st Mar 2011 9:29pm
