Home > In Car Electronics (L322) > Nav Screen Chromecast Mod
mjdronfield
I was gonna ask if there could be a kit of parts / parts list…. Not that straightforward then…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #606507 15th Sep 2021 9:23pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Chromecast into audio video splitter. Optical output.
Optical into splitter. 1 feed from chromecast, 1 feed from factory DVD changer. Button to switch between.
HDMI out into 2 way hdmi splitter.
1st HDMI to AV Convertor. Output from that goes into AV1 for RSE. I spliced into necessary feeds on the loom by the RSE module. (Shielded blue cable).
2nd HDMI to AV Convertor. Output goes to feed from RSE module to front screen. Need to cut the feed. I used a switch to reinstate factory TV/DVD connection when needed.
All are powered from USB connections. I used 12v to USB looks. Feed from rear 12v power outlet.
I think that’s about it. Shocked
Post #606509 15th Sep 2021 9:34pm
Icerover
Iceland
Chromecast
Hi JNC
I'm new here at the forum, recently got the car of my dreams who needs this chromecast upgrade
My car is NAS spec so I have to add video cable to the center monitor in the dash
You happen to have some some photos from the boot area of the connections to share?
And where you got the hdmi to av converters, I'm going to order them from UK or USA
Best regards, Asgeir
Post #614916 5th Dec 2021 8:45pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
I was hoping the same when I found this thread. My DVD player doesn't work anyway.
Currently I have an ipad plugged into the Rear sockets via a converter cable but it's very flaky and only works on the rear screens - a chromecast would be a perfect solution but I'm not sure I'm up to the challenge of splicing cables. 2010 4.4 TDV8 Vogue SE
Post #616349 14th Dec 2021 4:31pm
Azinho22
Hi, my DVD player finally has gone, just gives me a blue screen saying mecha error, i would like to bring my entertainment system up to date abit with trying to replace my dvd player and have the likes of a firestick to watch tv on the rse.
was there ever a plug and play set up to achieve this?
thanks.
Post #630907 7th May 2022 5:45pm
kooky_guy
Or even a set of detailed instructions? 2010 4.4 TDV8 Vogue SE
Post #632684 23rd May 2022 3:56pm
