Home > Maintenance & Mods (L405) > Lazer Lamps Grille - enough interest
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Following on from the threads about the poor lighting on the L405 compared to the L322 I’ve been looking to fit additional lighting to my 2014 AB.
Having had the Lazer Lamp grille kit on my Defender I was interested in doing the same on the L405.
They already do a kit for Discovery models -
So i enquired about sending them a grille for them to make the mountings for the kit.
They replied saying they would not do a one off kit but if there was enough interest then it might be added to the product range later this year.
The Discovery kits sell for £5-600and this includes the following -
What's included:
- x2 ST4 Evolution High Performance LED Spotlights
- x1 Mounting Kit (comprising 4x Brackets and fasteners)
- x1 Cutting Guide (comprising 4x Brackets)
- x1 Two-Lamp Wiring Kit
- x1 Installation instructions
So basically if they developed a kit would you be interested?
Post #539183 2nd Jan 2020 2:36pm
Mr Tee
Completely agree that std lights are cack, but I’d only be interested if the design looked better than that, l know there has to be compromise but it looks a bit heath Robinson, might be different in the flesh, could there not be a solution that’s easier? Perhaps mounting where the fogs are?
Post #539184 2nd Jan 2020 2:54pm
Unfortunately that's Laser's way of fitting them MrTee... They sell kits for lots of the Ford commercial range Whistle Might be fine for them but i have to agree, they look a bit "halfords" to be fitted to a fatty!
Post #539186 2nd Jan 2020 2:59pm
Mr Tee
Did you do a thread on your lightbar solution Craig? Can’t remember.
Post #539187 2nd Jan 2020 3:06pm
i agree with craig that they are nor stylish at all...
how about re-adjusting the fog light beams and connect them to the headlight high beam .. ... - .- -.
Post #539188 2nd Jan 2020 3:11pm
Weegie
Would they not be too low to conform to Con & Use regs? Fog lights are different and, legally, should only be used in fog or falling snow. John
GAP iiD BT-Sold
Post #539190 2nd Jan 2020 3:44pm
probably John...but i reckon the FF fogs are roughly the same height as a normal cars headlights ... ... - .- -.
Post #539191 2nd Jan 2020 3:50pm
LT
It's the dipped beam that's the issue for me. Don't the Lazers come on with full beam only?
I keep thinking about changing the bulbs to the brighter Osram ones that I've seen mentioned on here, but haven't got around to it.
Post #539192 2nd Jan 2020 3:50pm
Flyingfocrs
I have already upgraded to the Osrams and they are a definite improvement but I still want more on the full beam as I find there are dark areas and the cut off is quite pronounced.
I had considered mounting my spare ST4’s in the lower grille area but I think that because of the angle/curve they will look odd.
More odd than the ones in the top grille.
Any additional lighting is going to look out of place but the lazer grille is as good as it’ll get.
Post #539200 2nd Jan 2020 4:24pm
LT
I agree. The flush mounting in the grille is as good as it gets.
I'm interested in the kit. I'd probably buy an after market or used grille to cut up and keep the original one to go back on when I trade it in.Thumbs Up
Post #539207 2nd Jan 2020 4:39pm
Flyingfocrs
I already have a spare grille so the next option is to invest in a 3d printer and make my own mounting for the grille.
Post #539211 2nd Jan 2020 5:08pm
Mr Tee
Is there an option to have lights to fit the gaps, or is there a style of grill that allows more light through? The more gappy sort of honeycomb one might be ok? Happy to buy a crappy one for research purposes.
One of these :
https://www.ebay.co.uk/itm/Range-Rover-L40...Swl8Vcxrt4
Post #539218 2nd Jan 2020 5:34pm
Flyingfocrs
That is another option i’m exploring, as Craig did mount it behind the grille and then fit a more open style grille.
Post #539220 2nd Jan 2020 5:47pm
if you active vents behind the grill it might restrict your choice if lights.. ... - .- -.
Post #539224 2nd Jan 2020 6:14pm
Mr Tee
What are these active vents you speak of Stan?
Post #539228 2nd Jan 2020 7:05pm
