Home > Maintenance & Mods (L405) > MY18 Rear Lights Connector Wiring
JCW
EDIT - Resolved!
Has anyone tried fitting MY18 rear lights to an MY16-17 L405?
I’ve re-pinned the new lights per the Powerfuluk guide but the lights remain completely dead - Powerful does suggest the re-pinning for 2016-17 models may differ to 2013-15 but there’s no further info.
Also tried with the original wiring (i.e. an MY18 rear light wired as it comes) but still no success.
Heres a photo of the connector plug on the lights I’ve removed - can anyone help by checking the wiring on a 13-15 connector plug - assuming the colours haven’t changed I wonder if they moved things around on the 16-17 and then again on the MY18 onwards (although all the wires are black on these units which doesn’t help!)
Alternatively, does anyone know which wire colour relates to which function?
Thanks Thumbs Up
Jon
Post #538815 29th Dec 2019 1:47pm
i've fitted 2018 rears on my one Jon and i used these adaptors...its a 2 minute job to fit,
https://www.ebay.co.uk/itm/Range-Rover-Vog...SwupVdoyop
i gather you've seen the powerfuluk pic,
Post #538826 29th Dec 2019 3:51pm
...and also mine are genuine LR lights if that makes any difference.. ... - .- -.
Post #538835 29th Dec 2019 5:20pm
JCW
Thanks Stan, yes I followed the Powerfuluk re-pin chart you’ve posted above and I’d guess the adaptor looms achieve the same result, but the lights show no signs of life whatsoever, tried the indicators, fog, brake etc but nothing.
I’m also using brand new genuine MY18 light units so I’d hope these aren’t the issue.
I reckon the MY16-17 lights are wired differently, although yours is a MY16? so perhaps that’s a red herring.
Ideally I need a MY16 wiring diagram which shows the wire colours / functions.
Post #538839 29th Dec 2019 6:10pm
mines a 16my Jon, and it was a straight swap [with adaptors]...
one thing i would do is to re-fit the old lights and make sure all is well then start again.. ... - .- -.
Post #538840 29th Dec 2019 6:14pm
JCW
Hmm, I’ll have another play tomorrow - perhaps I’m missing something obvious Confused
Post #538841 29th Dec 2019 6:17pm
JCW
Ok, confession time - problem solved, it was simply that I’d not clicked the electrical connector fully home...
Feeling sheepish!
Post #538897 30th Dec 2019 10:32am
all working now then? ... - .- -.
Post #538898 30th Dec 2019 10:38am
JCW
Yep Thumbs Up
Post #538899 30th Dec 2019 10:40am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
looking good Thumbs Up Thumbs Up
Post #538965 30th Dec 2019 11:33pm
much better Thumbs Up ... - .- -.
Post #538975 31st Dec 2019 9:24am
JCW
I went for the SV version as I think they suit the dark exterior paint colours - there’s an eBay seller advertising sets for £675, he accepted an offer of £620 collected (brand new & genuine LR).
Post #538977 31st Dec 2019 9:35am
i considered the SV type but i prefer the normal ones, not that it makes much difference when they are on..
are your rears on when the drl's are on Jon? ... - .- -.
Post #538981 31st Dec 2019 9:52am
supershuttle
Need to start saving up Thumbs Up Geoff
Post #538983 31st Dec 2019 10:10am
JCW
Stan, checked today and the rear lights do not come on with just the front DRL’s on (light switch in the off position).
I’d prefer if they did - is there a setting somewhere to do this?
Post #539410 4th Jan 2020 7:24pm
