Home > Technical (L322) > Need some kinda USB power hub
GGDR
Hi guys,
With two dash cams, my iPhone, wife's iPhone, daughters iPhone, iPad etc etc I need ideally a six or more outlet USB hub. something-or-other.
Needs 2.1 amp (i.e. fast charging) per USB. I guess that is at least 12amps @5 volts (is that right, do I add the amps?)
The most powerful cigarette lighter I can see so far is something like this:
https://www.ebay.co.uk/itm/TeckNet-Multi-4...Swq5dcnIhX
....which is a four outlet 9.6A total.
I know I could get two of these btw, and that might be the best ideas, spreading the draw load over two cigarette outlets. I currently have one hidden under the centre console so I can add another.
Would like something a bit more, well professional really. Something wired into the 12v (fused of course).
Any ideas?
What does everyone else do in this USB age?
. Cheers, Greg
Post #538629 27th Dec 2019 7:04pm
Don’t forget your 2 lighter points in the back for the kids, Double USB in one of those should take care of the iPads etc.
Wire the Dash cams into the fuse boxes on piggyback fuses
Then put a double charger into the centre cubby with 2 wires to plug into. There is nothing that can't be fixed with a hammer😜😜
Post #538632 27th Dec 2019 7:12pm
GGDR
Thanks Mark, rear cig sockets - trying to keep free for a clean look.
Dash cams are USB so can't easily run them off a piggyback in the fusebox.
There's a lot of room under the centre console if you remove the lower rear facing cover.
That's where I currently have an extra , fused cig socket and a 4 x USB. But it's not powerful enough to run everything, nor enough outlets.
. Cheers, Greg
Post #538645 27th Dec 2019 8:10pm
andygts
Why not swap all the cigarette sockets for twin USB sockets?? Keep your clean look and apart from a cig lighter I can't think of any modern use for the factory sockets anyway.
Various versions availabe, linky for reference.
https://www.ebay.co.uk/itm/12V-24V-4-2A-Ca...pPN43_JZBA Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #538647 27th Dec 2019 8:51pm
GGDR
Thing is three cables for the dash cams etc run into the under-console area.
Connecting 'above deck' would mean they're visible albeit short.
I'd rather go 'below deck' and hide away the cables.
Then I'll leave a cig-USB converter in the visible plugs for whatever else that crops up.
. Cheers, Greg
Post #538650 27th Dec 2019 9:11pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I used one of these for my dash cam off a piggy back fuse holder. Would allow you to keep it all hidden and very compact.
https://rover.ebay.com/rover/0/0/0?mpre=ht...3255630897 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #538663 27th Dec 2019 10:46pm
For the rear, I added some extra trailing cig lighter sockets in the boot side panel electrics are, then ran the phone charger cables into the cubby in the arm rest in the rear seat - just tucked away nothing dismantled.
Post #538673 28th Dec 2019 7:21am
GGDR
Didn't know about those step down transformers, thanks!
So I am thinking about getting a bigger one, 10a or 15a something like this:
https://www.ebay.co.uk/itm/400W-15A-DC-DC-...Sw45VdXnjk
Then attaching this:
https://www.ebay.co.uk/itm/7-Port-USB-Hub-...4902.l9144
I like this one with the switches.
. Cheers, Greg
Post #538674 28th Dec 2019 9:04am
Brian Considine
Re: Need some kinda USB power hub
GGDR wrote:
my iPhone, wife's iPhone, daughters iPhone, iPad etc etc .
Are there any actual conversations in your car on a journey ? Whistle 2003 Range Rover Vogue TD6
Post #538694 28th Dec 2019 12:47pm
GGDR
I bought this: https://www.ebay.co.uk/itm/7-Port-USB-Hub-...4902.l9144
But it can't handle many amps.
But I think this is better:
https://www.amazon.co.uk/Aikenuo-Chargers-...1578818603
There are others similar, but this is highest amps/watts.
No idea why I couldn't find in the beginning.
. Cheers, Greg
Post #540289 12th Jan 2020 9:45am
