Home > Maintenance & Mods (L322) > Recommended Antifreeze - 4.4 TDV8
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Ok, I've looked in the Wiki and it only details the 3.6 and the petrol engines. The Owners book says Castrol SF but that's like rocking horse doo doo to find.
From what I've read I think it needs either a pink or orange, non-silicate?
Any other guidance opinions? Recommendations on where to buy? Would love to find some in EuroCarParts as they're easy to get too, Amazon next day even better!
Post #537660 16th Dec 2019 5:37pm
DrRob
https://www.advancedfactors.co.uk/service-...-168-c.asp
Their code is ADV907
https://www.advancedfactors.co.uk/adv907-2...5763-p.asp
3.6 is same spec as 4.4 according to Advanced Factors. Trust them 100% Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537663 16th Dec 2019 5:54pm
M@r]{
Thanks Rob. If I can't find something local that'll do nicely.
I have found this that Eurocarparts do. Looks like it is in spec?
https://www.eurocarparts.com/p/triple-qx-r...-523770511
Post #537674 16th Dec 2019 6:08pm
DrRob
Halfords website says silicate free OAT for the 4.4
https://www.halfords.com/motoring/engine-o...e-2-litres Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537732 17th Dec 2019 8:52pm
GGDR
Manual says Texaco (Havoline) XLC Coolant
What are people using on the 4.4TDV8 ?
. Cheers, Greg
Post #538698 28th Dec 2019 3:02pm
Baltic Blue
I bought a litre of Castrol SF from Opie a couple of years ago, but it is still unopened.
It’s not cheap, but 15% off at the moment.
Post #538702 28th Dec 2019 3:14pm
GGDR
If I'm topping up is is ok to mix types/brands?
. Cheers, Greg
Post #538708 28th Dec 2019 3:57pm
Any pink OAT coolant will do fine. Not had to top up the 4.4, but swapped it all out on the 3.6 for the euro car parts stuff.
NOT BLUE ——— NOT GREEN ——— PINK ONLY There is nothing that can't be fixed with a hammer😜😜
Post #538748 28th Dec 2019 10:14pm
DrRob
Pink OAT only with no silicone. I favour ready made stuff Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538772 29th Dec 2019 9:15am
GGDR
And by pink do you guys mean RED ?
Like this: https://www.eurocarparts.com/p/triple-qx-r...-523770482
Just checking.
. Cheers, Greg
Post #539055 31st Dec 2019 10:03pm
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #539094 1st Jan 2020 12:43pm
GGDR
Might have slightly over filled it.. Rolling Eyes
Should I suck some out?
. Cheers, Greg
Post #540163 11th Jan 2020 11:46am
DrRob
I would if it were me Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #540164 11th Jan 2020 11:57am
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
My coolant level is a little low so on cold start I get low coolant level warning which goes away once engine warms up a little. I ordered Castrol SF as the handbook suggests to op it up a little.
Castrol SF i bought is pink but the coolant in the car is orange? Is it ok to mix it? Or do I need to find an aronge coolant? Any other brand suggestions maybe available also in Germany? 2011 Vogue SE 4.4 TDV8
Post #678082 16th Nov 2023 4:31pm
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Re: Recommended Antifreeze - 4.4 TDV8
I just had to top-off my 2009 L322 Autobiography and the local dealer was out of stock. He told me that it's now $65/gallon. That's USD and a US gallon. OUCH! But, he told me that it's just Dexcool that I could buy at most auto parts stores. I picked up a gallon at my local store for $19.
And yes, it's orange!
I can't say that this'll work in your L322 but this is what I was told I could use in mine.
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #678085 16th Nov 2023 4:42pm
