Home > My Range Rover > Have I overspent on it
Sandyt
Hi all just some thoughts I was chasing a whumph noise which was intensely irritating there was also a slight metallic click
First stop rear diff as when the oil was taken out (it had only been there for 10k ) it was like treacle so the paint had dissolved on the inside to make a nice paste so replaced the diff. Noise still there - so replaced all the wheel bearings and front hub carriers noise better but still there but at different pitch and speed replaced the drive shafts all round big improvement but still there so front diff was next as it was a bit grumbly another improvement but a very faint noise only under load so rear prop off sent away splines sorted and also new bearing now it is quiet but in the middle of all that the handbrake went south so needed a new one and subframe dropped so my question is have I over spent on a 2007 car with 187k on it ?
Last reading with 11d was zero faults including fbh
It has cost me a bit of effort and about 4k
Post #537599 16th Dec 2019 6:59am
ilard
You haven’t overspent if you’re going to keep the thing for a few years longer. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #537602 16th Dec 2019 7:21am
Sandyt
Might keep it one more which will be about 25k miles then it can retire to the garden with the classic and p38 Smile
Post #537604 16th Dec 2019 7:47am
ilard
A museum. I like it. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #537605 16th Dec 2019 7:49am
As above - you haven't overspent until you sell it Smile
Post #537611 16th Dec 2019 8:22am
