![]() | Home > Maintenance & Mods (L405) > Nightmare to change upper suspension arms!!! |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2607 ![]() ![]() |
I haven't seen them but would expect that the nuts would be accessible using a socket etc without removing anything much. |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Sadly not Graeme... the bolts for the arms go through the body and into the engine bay. I was able to see one nut on the passenger side under the air box on the wheel arch but could not see the others. |
The parts diagram shows the panel section that the arms bolt to which confirms that the nuts will be inside the engine bay but doesn't show anything else. It is very strange that so much work would be required to replace a suspension arm.
Do you know what length / part number your arms are? Left and right can be different lengths so don't assume that they will both be short/std/long. |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
oops wrong thread |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
Presume you have done the job by now ? but for reference this is the official way to do it . Looks like many hours work as well.
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
Relieved that both sides were replaced on mine together with new shock absorbers in 2017, although at times I do wonder why |
I have not yet tackled this job no. I was secretly changing every other arm and track rod end first and hoping my knocking would go away |
