![]() | Home > Technical (L322) > Parking sensor fault |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Check the parking module in the rear near side cubby, mine had condensation in it & it packed up.
Fur3rd Member Since: 27 Nov 2019 Location: Chesham Posts: 24 ![]() ![]() ![]() |
Thanks I will check is this behind rear fuse board? |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
No should be other side under the nav dvd (at least mine was on 2012 model when I had a similar issue).
No, it's the opposite side. Left side as you stand at the rear.
thanks for all the help took the unit out and it was full of water |
