Home > Technical (L322) > Parking sensor fault |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
Check the parking module in the rear near side cubby, mine had condensation in it & it packed up.
10th Dec 2019 9:58pm |
Fur3rd Member Since: 27 Nov 2019 Location: Chesham Posts: 24 |
Thanks I will check is this behind rear fuse board? |
11th Dec 2019 7:09am |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 201 |
No should be other side under the nav dvd (at least mine was on 2012 model when I had a similar issue).
11th Dec 2019 8:37am |
No, it's the opposite side. Left side as you stand at the rear.
11th Dec 2019 8:39am |
thanks for all the help took the unit out and it was full of water
11th Dec 2019 11:46am |
