Home > Technical (L322) > Hazards flashing randomly
Mattpaddick
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
I have recently been told by my neighbor whilst i'm at work my 2011 V8 diesels hazard lights start flashing for about 20 minutes and then stop, no alarm sound just the hazards. I think i have a faulty bonnet sensor as it sometimes shows as open when its locked down. could this be triggering the hazards if locking in only single lock mode?
any advise would really help so i know what to look to replace/fix
thanks
Post #536343 4th Dec 2019 10:36am
i'd check that bonnet sensor first..
also if you have no 'noise' when the alarm goes off then the siren might need replacing.. ... - .- -.
Post #536348 4th Dec 2019 11:44am
Mattpaddick
Thanks for the advise, I might test the alarm as well with getting someone to double lock the car with me inside Very Happy
Post #536351 4th Dec 2019 1:50pm
open drivers window, double lock, and after about a minute stick your hand/arm through the window...that will set off the proximity alarm.. ... - .- -.
Post #536353 4th Dec 2019 2:06pm
Mattpaddick
Thank you for the advise, tried it and just got hazards, do you know where the siren is on these models? looked everywhere cannot find it.
Post #536576 6th Dec 2019 5:26pm
o my 2008 it was in a box ,on the top left [as you look into the engine from the front] ... - .- -.
Post #536579 6th Dec 2019 5:39pm
Mattpaddick
Thanks that's where I'm expecting to find it but am not. Maybe it was removed?
Post #536605 6th Dec 2019 9:38pm
Siren is behind the drivers wheel arch liner, behind where the mudflap would be Thumbs Up
Post #536617 7th Dec 2019 12:22am
