Home > Off Topic > Spline repair brass ? Tip pls! SOLVED
GGDR
Hi team,
RR unrelated, I've a shower valve with a brass shaft and a spline on the end to control it on and off.
The spline's worn and the brass cap that sits over no longer grips. The brass cap then takes a chrome handle so it needs to grip that shaft.
A quick check of encyclopedia YouTube and can't see an answer to this one.
The only option I am thinking is to file a flat section onto the knackered spline then drill and tap the brass cap that fits over it so a grub screw could drive in at right angles to the shaft.
Is there another way?
Many thanks. Cheers, Greg
Post #535891 29th Nov 2019 8:39pm
I would be inclined to clean up the splined shaft and inside of the brass cap and then use araldite to glue the cap in place so that it is located correctly and solid. Then drill a 3mm día hole through the side of the cap passing through the shaft and out the other side. Then cut an M3 stainless steel bolt to the día of the brass cap removing the head end and push it into the hole and finally fit the handle over.
If the shaft día is sufficient you could use M4.
Post #535895 29th Nov 2019 9:46pm
GGDR
Like your thinking nicedayforit!
Except I can't glue the cap on -I'll need it removable to do anything to the valve behind.
But like the M3/4 pin idea, I think thad would be better than my grub screw plan.
Easier too. Thumbs Up
The other idea I had would be to cut a slot into the shaft end and the cap too, fit a horizontal key. Not sure about this though as the cap fixes with a screw. Maybe the key is a bad idea.
I like the pin idea Thumbs Up Thumbs Up
Found a diagram, it's No 20 and 25:
 Cheers, Greg
Post #535897 29th Nov 2019 10:06pm
mpirie
How about cleaning up the splines and coating them with chemical metal, then putting the knob back on to take the pattern of the splines?
Put it all back together and let the chemical metal set before trying to use it.
I assume the manufacturer can't supply a replacement shaft?
Mike
Post #535898 29th Nov 2019 10:08pm
p38arover
Australia
Replace the shaft and valve. Unscrew it, and screw in a new one. They should be readily available at a plumbing supply store. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #535913 30th Nov 2019 1:43am
GGDR
Thanks Mike. Thumbs Up Hadn't thought of chemical metal. Just have to figure out how to fit the cap to hold the shaft, without it sticking. Maybe cling wrap.
And p38arover - I'm ordering a new valve with shaft but need something immediate.
. Cheers, Greg
Post #535930 30th Nov 2019 8:59am
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
I have the same unit as pictured, and also had the same problem, for the two days waiting for the part to arrive i just popped a small mole grip on the splines and operated it that way.
Post #535933 30th Nov 2019 9:35am
p38arover
Australia
I was just going to suggest Vise-Grips* (Mole Grips). Very Happy
* Brand name hence US spelling. Smile Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #535958 30th Nov 2019 12:09pm
For temp fix, wrap the splines in PTFE tape or similar (plastic bag?) for a "press fit" .
Post #535959 30th Nov 2019 12:22pm
GGDR
Sorted till the part arrives!
You can see I'm cutting the masonry nail I put in.
Then a short screw into the shaft which nips onto the nail to keep it from drifting
Thanks all!
 Cheers, Greg
Post #535964 30th Nov 2019 1:52pm
Proper job Thumbs Up Won't need a new one now Wink .
Post #535985 30th Nov 2019 4:24pm
mpirie
You could always have a bath instead! Rolling with laughter
Mike
Post #536014 30th Nov 2019 7:20pm
