![]() | Home > Maintenance & Mods (L322) > New L322 Owner - gearbox grief! |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
Currently dropped into 'limp' mode once warm.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
odd that as they are generally pretty bullet proof as gearboxes go.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I'd be interested to know what the difference is between a £2,000 rebuild and a £4,000 rebuild.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Nothing predictable about that – the ZF 6HP26 transmission has an enviable reputation for reliability. Having said that, these are the known issues that occasionally affect this transmission : 1. Transmission won’t shift into 4th, 5th & 6th gears (E clutch slipping due to stator shaft bush wear/leakage) 2. Erratic gearshifts – particularly 3-4 (faulty solenoids) 3. Clunky 2–1 rollout shifts (requires software update) 4. Drops into neutral when accelerating hard/turning corner from stationary (clamp bolt for shift cable seized in shift lever) 5. Failure of output shaft spline through fretting corrosion (lack of lubrication during assembly at factory) 6. Clutch packs destroy themselves following fluid change and adaption reset (never reset adaptions unless mechatronic/solenoids are replaced) Phil |
jonbaobao Member Since: 12 Jun 2014 Location: Taiwan Posts: 6 ![]() ![]() |
Dear Phil:
