![]() | Home > Technical (L322) > Help please - dropped hose spring retaining clip!!! |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
John,
TDV8John Member Since: 08 Nov 2015 Location: Kent Posts: 19 ![]() ![]() ![]() |
OK thanks John, I'll just give it a bit more of a tug when I try again.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
counter intuituvely you push the clip inwards and the fitting should release. There is nothing that can't be fixed with a hammer😜😜
Oh right, that is very helpful advice thank you!
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 895 ![]() ![]() ![]() |
I replaced my expansion tank (oil cooler gasket was leaking and had oily film on the inside of the expansion tank) requiring removal of that lower hose fitting, I also lost the same spring clip but luckily found it hiding in the subframe.
OK thanks again.
Ps if the clip is completely removed opposed moved into the ‘remove’ position, the fitting should just pull off. |
All sorted this morning with the advice above put into action.
Brill |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 410 ![]() ![]() ![]() |
Hi TDV8John,
Found the spring clip... |
