Home > Technical (L405) > Remote FBH retro fit
Ent
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I can’t see why you couldn’t but the receiver in the engine bay somewhere and run the 3 cables direct to the Eberspacher? IP rated adaptable box and a few splices and voila
Post #535066 21st Nov 2019 8:33pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Looks like I’m going to go down this route ent as I’ve practically stripped the rear out to find the wiring connectors with no luck
I know there are 3 wires into the receiver. One will be the earth one will be a permanent positive but where is the other one going to go Big Cry Big Cry Big Cry Big Cry Big Cry
And obviously a separate antenna
Any help appreciated. Thumbs Up Thumbs Up Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #538235 22nd Dec 2019 3:04pm
aljo
Ent wrote:
As you can see it’s only 3 wires and the fakra antenna. I couldn’t trace out where the antenna ended up and wether or not it was connected( I’ve read somewhere that it’s connected or should be connected to the aerials in the rear windows but I can’t confirm that) hence why I bought a separate one which works over 100m now.
ent could you tell me exactly where abouts in the rear area that picture is please Thumbs Up
if it is there im having difficulty finding it Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #538716 28th Dec 2019 3:54pm
Ent
Laughing
I’ll take a video tomorrow pal. PM your email and I’ll fire it over.
Post #538741 28th Dec 2019 8:15pm
aljo
Many thanks ent pm sent Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #538761 28th Dec 2019 11:08pm
capcgn
Germany 2006 Range Rover Westminster 4.4 V8 Chawton White
I have the same problem. I have a 2016 L405 SDV8 European car. The cables are not behinmd the rigth C-pillar. I opend all covers and there are not tucked away. The loca´tion had changed. Did you found it or do you know where it is for the 2016 and up? Thanks in advance
Post #581510 28th Jan 2021 4:44pm
