Home > In Car Electronics (L322) > Venture Cam died (Neebee first R/R)
On The Edge
Wales 2005 Range Rover Autobiography Td6 Mariana Black
Hi (Newbie first R/R so I no nothing about them
its an old one so guess ill be on here quite a bit for your expert help and advice
My Venture Camera is dead - was working - Now nothing not even the torch
Can anyone please tell me if there is a fuse somewhere for it as cant find anything in my owners manual ?
Thanks.
Post #533954 12th Nov 2019 6:06pm
essex boy
you can get replacement battery from e bay
Post #533960 12th Nov 2019 6:45pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
First check that you have power to the docking port ( two little brass connections at the bottom). If so then you may need new batteries, as they do fail. Loads of threads on here. Thumbs Up
Post #533961 12th Nov 2019 6:48pm
On The Edge
Thank you
Great will try to connect my volt meter to the two little nipples (guess ignition needs to be on)
If I get a reading will then search for some replacement batteries and on how to fit them
Post #533966 12th Nov 2019 7:13pm
