Home > Technical (L405) > New battery....same old low battery message |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
Same here, I drive a different works vehicle most of the time. Never had a starting issue, but when I do want to go out on a frosty morning the biggest letdown is when the FBH won't complete it's duration. 1st world problem tho! |
10th Nov 2019 7:17pm |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
No problem, hopefully that is the remedy to your issue. Let us know. |
10th Nov 2019 7:46pm |
Thanks Brad, your advice makes sense and I'll post results accordingly |
10th Nov 2019 7:51pm |
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 |
2 Battery, non stop/start VSE, 2014.
13th Nov 2019 9:26am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35402 |
interesting , thank you... ... - .- -.
13th Nov 2019 9:32am |
Unnecessary quote removed
13th Nov 2019 3:36pm |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
In the Autel service tool there is a page to reset the back up battery , but I think this is only used for the telematics in the 3.0 models as there is also a routine to reset the telematics themselves after disconnecting / replacing the small battery ( 15 ah agm) the 2nd battery in the v8 cars is huge by comparison !
13th Nov 2019 10:02pm |
Goodfella Member Since: 04 Jun 2017 Location: Essex Posts: 74 |
Bonjour Obi Cam Craigobi, Did you try the “new battery” reset with an OBD approach for yours? If so did it work? |
24th Apr 2023 3:17pm |
Alan Moules Member Since: 14 Jan 2025 Location: Cambridgeshire Posts: 2 |
After receiving the "Low battery" message I had a new battery fitted and the message disappeared. A few weeks later it reappeared, so I had the stop/start battery replaced and recoded. Message was gone when I picked the car up. Started it the next day and the "Low battery" message re-appeared and I noticed that the interior lights and courtesy tailgate did not work with the car engine not running. After lots of web searches I decided to take a look at the battery connection. To access the main battery you need to remove the spare wheel. When I lifted the wheel out of the well the interior lights came on, when I put the wheel back in the well I found that when I moved it around I could get the interior lights to go on and off. There was nothing obvious wrong with the cables so I pushed the spare wheel to the front of the wheel well so it was not near the battery terminals and it solved the problem. Bolted it back in place and so far I have not seen the "Low battery" message again. So far so good, fingers crossed. Worth checking I think. |
14th Jan 2025 3:00pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1521 |
@Alan,
14th Jan 2025 3:38pm |
Battery terminals both solid, tight and super clean. |
14th Jan 2025 3:51pm |
