![]() | Home > Technical (L322) > Preparing to change battery |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7978 ![]() ![]() ![]() |
It's in the wiki (top right under where it says fullfatrr.com)
TimperleyRR Member Since: 13 Aug 2016 Location: Manchester Posts: 50 ![]() ![]() ![]() |
Thanks
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1099 ![]() ![]() ![]() |
not on a 2006, no ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
You may have to do the one-touch on the windows it may not be relevant on your year. |
Thank you all
chris_stendall Member Since: 18 Feb 2019 Location: Nottinghamshire Posts: 9 ![]() ![]() ![]() |
So it would appear I have messed up! Didn't realise there was a procedure to replacing the battery and now the car wont start! Is it a case of needing the tool to inform battery change has been completed or am I in dire straits now? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35546 ![]() ![]() |
make sure that the battery is indeed fully charged and check all the connections and that you have connected all the wires..... ... - .- -.
