Home > General (L405) > My Sept 2014 AB vs my father in laws June 2015 Vogue
BigladUK
United Kingdom 2014 Range Rover Autobiography SDV8 Causeway Grey
My father in law and I have FFRR's , his is a low mileage ( 40k ) June 2015 Vogue and mine is a highish mileage (79k ) AB, they are both approved used and both the 4.4V8
I have a vagueish question, I don't drive my father in laws car very often but when I do it's so tight and firm in it's drving, it's hard to describe but it drives so nicely. On the other hand mine, in comparision, is no where near as tight a firm. Mine drives fine but it's night and day in comparision, even my girlfriend in the passenger seat could tell the differnce.
We've had the ARC ram bushes changed on mine ( I think ) but is there something super obvious that is different between the cars that would cause this or perhaos something worn on mine that would cause this effect ?
Thanks in advance for any assistance
Si
Post #532443 28th Oct 2019 1:33pm
Do they have the same size wheels ?
Same brand of tyre ?
Post #532444 28th Oct 2019 1:40pm
BigladUK
Actually they don't, they are both 22in but different styles
I have this style
And he has the more common
Tyres.....I'm not sure about, I could check if you think it will make a difference ?
Si
Post #532445 28th Oct 2019 1:45pm
If they are both 22's the brand shouldn't make too much difference, but it's possible - my wife can tell when I've switched from summer to winter continentals - both 22's
Try checking the pressures ?
Post #532447 28th Oct 2019 1:51pm
BigladUK
I run mine at the lower number ( you know there is 4 people in the car or 27 people ), I wonder if they need more air then. I can try that Smile
Thanks
Si
Post #532449 28th Oct 2019 1:55pm
Maybe just check what your FiL has his at ?
I guess it could be bushes or something else, but would start with the simple stuff.....
Post #532451 28th Oct 2019 1:58pm
BigladUK
Great,
I've got him to check his ( from the service menu ) and I'll check mine
I shall report back
Si
Post #532452 28th Oct 2019 1:59pm
Mr Tee
I have a 63 plate one, higher miles circa 85k and its tight as a drum. Suspension components are the normal places to start.
Post #532454 28th Oct 2019 2:03pm
BigladUK
Thanks, the wierd thing is I was happy enough until I drove his car , I might have the dealer drive both cars back to back
Si
Post #532458 28th Oct 2019 2:17pm
Vogue
4 wheel alignment makes a big difference in handling - a good sign if it’s out is if the tyres are wearing unevenly 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #532488 28th Oct 2019 7:09pm
His car will have the improved EAS block with twin valves, the updated ARB complete with harmonic balance weights! etc etc...
Its been done on my 13MY and its night & day! Have a schmooze through my thread below... All the info is there Thumbs Up
https://www.fullfatrr.com/forum/topic47985-45.html
Post #532490 28th Oct 2019 7:12pm
dolph34
What struck me was your girlfriend has been in your father in laws car !!!!! Are you a danger freak or suicidal, what if your wife ( his daughter) finds out Laughing 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #532496 28th Oct 2019 7:54pm
Laughing Laughing Rolling with laughter Bow down
Post #532516 28th Oct 2019 11:28pm
BigladUK
Thanks all for your help
Tyre pressures were pretty much the same on both cars so I've ruled this out
Tyre wear is even so I don't think it's alignment
Craig, I couldn't find the specific details about the EAS block and ARB with harmonic balance weights, would you be kind enought to give me more details, this sounds like a good place to try , what are the costs ( I have warranty ) and what actually need to updated , also I have no clue what an EAS block or ARB are LOL
LOL @ the comment about my girlfriend, i like to live on the wild side
Si
Post #532524 29th Oct 2019 7:39am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Mine has had the new ARC valve Block and balancer and new bushes all round and can't say I noticed THAT much difference in road holding etc. The only things that I noticed was that a) the awful front clunking noise had now finally been fixed but has been replaced by b) a god awful hydraulic hissing sound from under the car where the ARC block sits, when the car is at idle at traffic lights for example. Crying or Very sad
When I did notice a difference once was when I got a 6 month old courtesy AB while mine was in for repair, now that difference was chalk and cheese. Getting mine back felt like I was driving a jelly. When I spoke to the master Tech he said there had been significant suspension revisions between mine and a 2019 spec. Shocked
Post #532528 29th Oct 2019 9:33am
