Home > In Car Electronics (L322) > Alarm goes off when it rains |
Shambler Member Since: 04 Nov 2017 Location: Gloucestershire Posts: 41 |
Ok so update on this weird fault....
27th Oct 2019 6:47pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2584 |
I may be off kilter but this is usually related to the BCM under the passenger seat I think, mine used to do exactly this when parked down hill in rain someone with a bit more knowledge will hopefully be along soon |
27th Oct 2019 7:06pm |
Ahhh ok thanks buddy, gives me a start point, did yours smell of burning/melted plastic or wires? Could explain the niff near Centre console, Is it easy to get to or is it a seat out job do you know? |
27th Oct 2019 7:27pm |
Removed both the BCM and the LCM sat them on a radiator in the house for a couple of days as someone had suggested they may get damp, refitted them and reconnected the battery and hey presto all seems fine....didn’t even bong up with HDC inactive etc faults.
21st Nov 2019 9:18pm |
So update again....was fine for a couple of days, then a bit more rain and puddles and it’s started playing up again back to the drawing board and trawling the tinternet |
25th Nov 2019 5:29pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Have you tried switching the internal alarm sensors off when you lock the car? |
25th Nov 2019 5:55pm |
I don’t think it’s anything to do with the alarm, it sees to be a water ingress problem, somehow getting into either the lcm or the bcm? I think it may (hopefully) be blocked sunroof drain tubes? |
25th Nov 2019 8:18pm |
