Home > Maintenance & Mods (L405) > P040D-00 (2F) Exhaust gas recirculation temperature sensor A |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
Does anyone know which sensor this relates to?
16th Oct 2019 2:55pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
https://www.fullfatrr.com/forum/topic48131.html
16th Oct 2019 3:00pm |
Will it be the same though as that topic is for TDV8, mine is a SDV8? Current
16th Oct 2019 3:08pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Andy, essentially the same engine -- so we believe it to be the same issue.
16th Oct 2019 3:16pm |
Virtually the same car only difference our 322’s are a better shape.
16th Oct 2019 3:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
16th Oct 2019 3:20pm |
Just had a little play and Bank 2 sensor 2 is at a constant 0V all the other EGT sensors fluctuate.
16th Oct 2019 3:29pm |
Less flippant reply
16th Oct 2019 3:34pm |
16th Oct 2019 3:59pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4304 |
Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
16th Oct 2019 4:45pm |
A few of us have that error with no obvious issues but if they will replace it for free then Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Oct 2019 4:46pm |
It's on a warrantywise warranty and they've tried once but done the wrong sensor , looks like they've done the one in the EGR pipework.
16th Oct 2019 5:25pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
it's not documented and it flummoxed me and a few of us for a while, not the first time I've read a dealer replaced the wrong one - this led to dealers proliferating the story that it's a ghost code / that all do that sir. If you haven't read my guide it's on the NS exhaust manifold. Once they find the correct location, the job can still go wrong without repeated WD40 soakings (the nut can round off)or in Craig's case they didn't clean the thread out properly before fitting the new one (false torqued nut). Get it wrong and the manifold's got to come out which is not pretty. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
16th Oct 2019 6:27pm |
17th Oct 2019 9:13am |
