Home > Technical (L322) > Electronic Park Brake release 2011 4.4 tdv8
Baltic Blue
HELP !!!!
B.B. is well and truly stuck in my garage.
It has not been used for 5 weeks and is now refusing to budge.
The EPB indicator on the dash is showing it release and operate as normal, but I can’t hear any movement ???,
I have searched for help regarding trying the emergency release cable but can’t find anything.
Has anyone ever used theirs?? If so any help appreciated.
My next plan is to jack up the backend and see if the wheels are free.
I can’t drive forwards or reverse, and now it is throwing up a gearbox fault alert.
Any tips or links appreciated.
Post #545530 29th Feb 2020 10:02am
the emergency release is in the rear right hand cubby hole Mike...i think its a whiteish colour tab.. ... - .- -.
Post #545532 29th Feb 2020 10:27am
http://www.fullfatrr.com/gallery/albums/us...ation..pdf ... - .- -.
Post #545533 29th Feb 2020 10:29am
Baltic Blue
Cheers Stan.
I am about to go and look for it, but I think I will jack up the back end first to try and see which side is stuck, then see if it releases with a pull.
It’s not easy working on it because my garage is so tight, but I think I can get both back wheels off the ground.
I will report back later if I make any progress.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #545535 29th Feb 2020 10:45am
Baltic Blue
I have pulled the emergency release, but car still refusing to move.
I haven’t jacked it up yet.
Just going to check iid for faults.
Gearbox Fault clears when I press OK, but returns as I select reverse and try to drive.
Big Cry Big Cry Big Cry
Mike.
Post #545540 29th Feb 2020 11:14am
Baltic Blue
All fault codes clear, but this returns when I select reverse and try to drive....
Post #545545 29th Feb 2020 11:26am
GGDR
Can you creep forward in low range Mike? Just a few inches? Cheers, Greg
Post #545546 29th Feb 2020 11:26am
GGDR
What is telling you it’s was the handbrake? Cheers, Greg
Post #545547 29th Feb 2020 11:27am
Baltic Blue
Not without demolishing the house Big Cry Big Cry
Front bumper touching garage wall.
Jacking back end up and dragging seems only option.
Post #545548 29th Feb 2020 11:30am
Baltic Blue
Greg,
Nothing is telling me it is handbrake ...
It just seemed a good likely cause and somewhere to start.
Jacking up back end next option.
Post #545549 29th Feb 2020 11:42am
DrRob
Dont drag it out. You.may cause more damage. Get it on some tyre dollies Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545552 29th Feb 2020 11:57am
DrRob
Cycle through low box and back Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545553 29th Feb 2020 11:58am
Baltic Blue
Thanks to a call from Greg,
I was trying to manually paddle through the gears and couldn’t, then I noticed when I selected Neautral that it was flashing N rather than solid display.
Just trying to select low range brought up message to select N to change range, then suddenly N became a solid display, then I selected R and it moved.
Just taken it for a quick run round the block and all seems OK.
I will take it for a longer run after I get a quick bite of lunch.
Thanks to all
Cheers
Post #545555 29th Feb 2020 12:31pm
Baltic Blue
Just been for a good run, manually paddled gears lots plus high and low ranges.
Conclusion...
100% it was not the brakes sticking, but at least I now know how to manually release the park brake.
Manually changing high to low and through the gears eventually cleared it., but I still don’t know what exactly was stuck.
Post #545572 29th Feb 2020 1:58pm
How many miles has yours done sir? Maybe the gearbox oil is getting old/moisture in?
Post #545573 29th Feb 2020 2:00pm
