Home > Maintenance & Mods (L322) > Air suspension bong AGAIN any ideas |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
I'd check the airline connector at the top of the strut/s, ensure height sensors are OK
23rd Oct 2019 9:09am |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 295 |
Thanks Jo it’s a bit strange but also in a few occasions when lowering the suspension to lowest setting it went down then raised straight back up to extended mode saying clear obstruction when there was no obstruction present only when driving off it would reset back to normal ride height. A possible sensor maybe? But doesn’t explain the fault code I’m getting plus surely if a sensor is at fault it would thow that up as a fault code?
23rd Oct 2019 9:33am |
JPJ64 Member Since: 23 Jun 2017 Location: Newcastle upon Tyne Posts: 49 |
Sounds like a duff sensor. Mine did something similar when the front left sensor failed. You can check the sensors using your IId tool. If you graph the current height for each sensor you can see which one is fluctuating indicating failure |
23rd Oct 2019 9:44pm |
