Home > Maintenance & Mods (L322) > Should viscous fan come on full power when started?
Danwilderspin
On my 4.2 my viscous fan has recently started coming on at full power when the car is started is that normal? After 2kins or so it quietens down... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531537 20th Oct 2019 1:04pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I've noticed this on mine recently & I'm thinking that it may be due to the drop in temperature, where it's taking a little longer to reach the desired system sensing, If you get my drift.
Post #531542 20th Oct 2019 2:26pm
Danwilderspin
I’m guessing you have the jag engined 4.4? If so likely we have the same thing. Did it do it last winter though? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531544 20th Oct 2019 2:47pm
mpirie
I was under the impression that a viscous coupling on a fan engages when cold and gradually disengages as it reaches it's operating temperature.
If the temp goes above normal, then it engages again to cool itself and the associated radiator.
There's a viscous fluid inside that thickens and thins depending on temperature.
Mike
Post #531545 20th Oct 2019 3:14pm
mpirie
There's a viscous fluid inside that thickens and thins thus drag, depending on temperature
Mike
Post #531546 20th Oct 2019 3:15pm
Highroller
Your're right 4.4 AJ engine. Difficult to remember, but not had any cooling issues.
I can remember hearing the fan cut in quite loudly back on a very hot day in the summer. Fan / engine quite after initial start up.
Mpirie, correct in what you saying. However these viscous fans operate as a normal fan, but also have a built in wiring loom / connection to cut in /out etc on the RR
Post #531547 20th Oct 2019 3:49pm
Highroller
Found this on Rave.
[img]http://www.fullfatrr.com/gallery/albums/userpics/17444/Fan.pdf[/img]
Post #531548 20th Oct 2019 4:01pm
Brian Considine
My TD6 (2003 L322 Vogue) seems to do the same occasionally - will have to make a mental note of ambient temperatures in future. 2003 Range Rover Vogue TD6
Post #531551 20th Oct 2019 4:24pm
Sandyt
From memory the viscous fan if it has locked up ie engine was hot when you switch off it stays like that and doesn't reset until you restart - I may not be exactly correct but it is along those lines so I was told
Post #531585 20th Oct 2019 9:16pm
Danwilderspin
Thanks sandy - so does yours sometimes do the roar when it starts as you have the same as me for 60 seconds or so?
Also when you turn the ignition on but don’t start do you get this noise form the supercharger pump up front?  Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531588 20th Oct 2019 9:39pm
Sandyt
Yes not every time but most and I changed the fan as well as all pulleys alternator zircon compressor water pump etc when it was 10 yrs old did it before and still does it
Post #531594 21st Oct 2019 3:16am
Danwilderspin
Thanks - do you get the buzzing sound in the video? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531611 21st Oct 2019 8:42am
stu1
There is no buzzing from mine (changed for a new one about a year ago).
There may be no coolant in it (check by removing the top pipe to it) or on its way out. You can access it quite nicely by removing the headlamp.
Post #531697 21st Oct 2019 4:57pm
Danwilderspin
Great stuff thanks Stu
So with the ignition in position 2 and engine off no buzz like that?
Are you saying take the top hose off and there maybe no coolant if so i need a new one? Would I not see any symptoms of it failing or faults? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531698 21st Oct 2019 5:05pm
stu1
Correct no buzz. The problem may be the pump is trying to pump air - it's pretty easy to check, just pull the top hose off, if coolant comes out all good, otherwise you'll need to prime it and then bleed it (see the WSM - ignition switch to II and then the bleed screw on the expansion tank).
If the problem isn't air, and it's just getting noisy, keep an eye on it or replace it for a new one.
Post #531814 22nd Oct 2019 4:39pm
