Home > Maintenance & Mods (L405) > P040D-00 (2F) Exhaust gas recirculation temperature sensor A
andygts
Does anyone know which sensor this relates to?
P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high
I've just picked the car up after apparently having this fixed under warranty, plugged the IID in and it was still there, cleared it and it came straight back. I'm now awaiting a phone call Yawn
The sensor they have just fitted is LR022904 - Sesnor exhaust gas - temperture Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #531119 16th Oct 2019 2:55pm
Baltic Blue
https://www.fullfatrr.com/forum/topic48131.html
We are lucky to have a site expert... Thumbs Up Greg.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #531120 16th Oct 2019 3:00pm
andygts
Will it be the same though as that topic is for TDV8, mine is a SDV8? Current
Previous
Post #531122 16th Oct 2019 3:08pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Andy, essentially the same engine -- so we believe it to be the same issue.
See other posts about this -- for some the fault causes untold trouble, others like myself apparently no adverse effect -- the thought being it depends if the sensor fails in either high or low -- one causing issues the other not, though I don't think there is enough data to confirm that. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #531124 16th Oct 2019 3:16pm
Baltic Blue
Virtually the same car Rolling with laughter only difference our 322’s are a better shape.
Post #531125 16th Oct 2019 3:17pm
Laughing ... - .- -.
Post #531127 16th Oct 2019 3:20pm
andygts
Just had a little play and Bank 2 sensor 2 is at a constant 0V all the other EGT sensors fluctuate.
Time to have a read of that thread and decipher if its in the manifold or downstream
I have no adverse effects at present caused by this, no lights on anyway but as its under warranty they can fix it with where some of the sensors are located Rolling with laughter Current
Previous
Post #531128 16th Oct 2019 3:29pm
Baltic Blue
Less flippant reply Bow down
Mike Very Happy G reg 2.5VM Vogue Portofino red 1991- 1999
Post #531132 16th Oct 2019 3:34pm
Baltic Blue
Post #531137 16th Oct 2019 3:59pm
DrRob
Mike.
Thumbs Up Rolling with laughter Rolling with laughter Whistle Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #531143 16th Oct 2019 4:45pm
DrRob
A few of us have that error with no obvious issues but if they will replace it for free then Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #531144 16th Oct 2019 4:46pm
andygts
It's on a warrantywise warranty and they've tried once but done the wrong sensor Rolling with laughter, looks like they've done the one in the EGR pipework.
On the plus side they did fit a new waterpump to to the preheater and that now works, had a few cold mornings last week and missed my preheat Big Cry
The L322 is definitely a better shape for washing, I've just given it its first wash in my ownership and it took a hell of a lot longer. Current
Previous
Post #531147 16th Oct 2019 5:25pm
GGDR
Craig had it on his 405 SDV8
Same issue.
Dealer screwed up the warranty replacement too.
. Cheers, Greg
Post #531150 16th Oct 2019 5:59pm
GGDR
Quote:
they've tried once but done the wrong sensor, looks like they've done the one in the EGR pipework.
it's not documented and it flummoxed me and a few of us for a while, not the first time I've read a dealer replaced the wrong one - this led to dealers proliferating the story that it's a ghost code / that all do that sir.
If you haven't read my guide it's on the NS exhaust manifold.
Once they find the correct location, the job can still go wrong without repeated WD40 soakings (the nut can round off)or in Craig's case they didn't clean the thread out properly before fitting the new one (false torqued nut).
Get it wrong and the manifold's got to come out which is not pretty.
. Cheers, Greg
Post #531154 16th Oct 2019 6:27pm
andygts
stumbled accross this thread aswell https://www.fullfatrr.com/forum/post505564.html which shows it on a L405.
I'm still waiting for my call back from the garage Whistle
I've got a feeling that warrantywise are going to stick two fingers up now and blame the garage and the garage won't want to sort it becasue they aren't being paid leaving me stuck in the middle. Current
Previous
Post #531202 17th Oct 2019 9:13am
