![]() | Home > Finance, Insurance & Warranties > To extend the warranty or not? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7991 ![]() ![]() ![]() |
Doesn't changing your own oil invalidate the warranty ? |
Singh911 Member Since: 04 Jun 2017 Location: London Posts: 51 ![]() ![]() ![]() |
I don't know - but i dont tell them about it either.
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Personally I would extend.
Ah - you're doing that in addition to a paid for & documented service ? In which case I guess it's OK as long as they don't find out. If you have a claim it would count against you.... I didn't extend mine & have had 3 years of trouble free motoring. As always, it's a gamble - but the warranty will not be a loss maker - so priced to make money. That means on average it's likely to cost more than the claims - so it's basically a premium for partial peace of mind should the worst happen...... I say partial as it appears that the worst thing that happens on the V6 is bearing failure and that's deemed a design failure by the warranty and you need to rely on a good will payment from JLR to cover part of it....... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35592 ![]() ![]() |
if you think any repairs will be less than the full LR warranty priced at £1600 then i wouldnt bother...
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
My thoughts are that owning a high value vehicle, regardless of make or model, without a warranty is like playing Russian roulette. With Land Rovers reputation for reliability I think that if I owned a modern version worth more than £25k I would put a warranty on it.
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
My 2013 SDV8 is just gone out of the LR 2 year used approved warranty. I've decided not to extend as I've had most the known issues already fixed under the warranty, knocking front suspension, secondary turbo replaced etc. I've got a good independent near me so I'm going to take my chances. 2019 L405 SDV8 Autobiography
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1399 ![]() ![]() ![]() |
If you are thinking of taking the LR warranty, check the terms carefully as one of the two I was offered had a claims limit that would have prevented it covering the full cost of (say) a catastrophic engine failure. LR's attitude to the corrosion on the wheel arches on my last 322 led me not to take the warranty, and over years four and five all I had to pay beyond routine servicing was about £700 for a new starter motor, so my decision was profitable.
We extended the warranty on our 3.0 TDv6. £145.50/ month over 10 months without breakdown cover |
Thank you for all the replies.
Just by way of update, i have a copy of the latest warranty booklet. The extended warranty says it covers the following (quoted from the bookley) - specifically mentions "crankshaft and bearings".
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
It also says that it won’t cover what they consider to be “known design faults” and they will refer you back to LR themselves. |
