Home > Technical (L322) > 2006 L322 TDV8 battery drain - blower motor running |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 45 |
Sounds typical of FSR (final stage resistor) failure. There is a good write up re it’s replacement in the Wiki on this forum. |
1st Aug 2024 11:47am |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 356 |
Yes the FSR has failed only solution is to disconnect the battery to stop the fan then replace the unit. It’s a fiddle but can be fine at home. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
1st Aug 2024 2:58pm |
