![]() | Home > Technical (L322) > Steering wheel not retracting |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I’ve had my TDV8 for 7 months now and I’ve just noticed the steering wheel doesn’t retract when switching off. I think the reason I hadn’t noticed was because I’d disabled this on the TD6 a few years ago and I’d got so used to it not doing it.
Its settable in the dash menu, i think its easy entry/exit |
I don’t recall seeing that setting but I’ll have another look in the morning. Thanks Craig. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
I’ve just had a look and the easy entry/exit is ticked. Must be something else stopping this working then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
I’ve always had it to the highest position.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Seat memory ecu might be gone. 2010 3.6tdv8 180k km.
Seat ECU seems fine. All the memory functions still work? No faults logged with IID 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Popeye Member Since: 15 Sep 2017 Location: Kent Posts: 27 ![]() ![]() ![]() |
Are they supposed to retract?? Mine just raises to the highest position which I thought was normal. |
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
Could be a Motor fault on the Steering Column. Had to change one on my last L322 due to the Ignition Key not turning. Got a Second Hand one but when i fitted it the Up and down wouldn't work so took the Motor off the Old one and swapped it out.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
if it al works manually on the lever then the key isnt telling the ecu to do its bit ..
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
I really must 'STOP' reading sensible advice on forums! I tried the spare key in order to leave it in the car for use on the garage lifts. Big mistake. ![]() I get into the car as normal. (heck it is my car thus everything is where it should be). and I instinctively apply the seat belt. Put unused by me 'spare ignition key' in. Now the we have the complete FF-Anti-Villain mode. With the seat belt fastened and the previously unused spare key in, the seat starts to move forward and down, the steering wheel is coming towards me and also heading down. The lap belt part is getting tighter and tighter, and still the steering wheel is moving inexorably towards me. Breathing could become an issue, the shoulder strap part is now also trying to strangle me. Finally all movement stops and I'm almost 'immobilized' but my right arm still seems to be sending signals to my hand. I manage to stretch down and with a last effort hit the "#1 seat memory button". DEEP JOY The computer kicks in and the seat starts to move away, the steering wheel moves inwards and upwards, blood starts to recirculate in my 'nether regions', breathing is now a possibility, and "Normality has been Restored" The morale is, do not use the spare key unless you are sure that a 7 year old did not program it to the car! Best Rich |
