Home > Technical (L405) > Removing retractable side steps
cadoganpier
United Kingdom 2018 Range Rover Autobiography SDV8 Loire Blue
Is this easy to do as I can't stand them.
Post #529466 29th Sep 2019 10:08am
on your 2012? ... - .- -.
Post #529467 29th Sep 2019 10:17am
cadoganpier
Nope, 2017 4.4 VSE
Post #529468 29th Sep 2019 10:22am
time to change your car profile then. Wink
re your question, very easy if you dont mind crawling underneath...put the FF in off road and use ramps and there will be enough room to undo the bolts...the wiring and ecu can stay in place..
if you are selling ,give me a pm.. ... - .- -.
Post #529469 29th Sep 2019 10:29am
Unless you want to sell them - just turn them off.
I have mine permanently off - I figured for the hassle of removing them, I'd just leave them there for the next owner. Though they have been used once or twice with elderly relatives, so worth keeping IMHO
Post #529485 29th Sep 2019 2:54pm
palli
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
I always used to keep mine turned off, on this RR and previous, until my hip started giving me grief.
Now I find them invaluable.
You never know whats around that corner. 2008 Vogue Black - gone
2012 Vogue SE White - gone
2016 Autobiography Blue - gone
2019 Autobiography Grey - gone
2020 SVAutobiography Red
Post #529491 29th Sep 2019 3:41pm
Just switch them off! Should be a valuable asset when sale time comes around sir... Thumbs Up
Post #529532 29th Sep 2019 10:30pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
be aware that if you do want to take them off you will need to replace a front trim to the sills which I doubt you have.
When DSS are fitted at the dealership, that piece of trim is removed and usually thrown away.
Post #529685 1st Oct 2019 12:33pm
