![]() | Home > Technical (L322) > Lunched TD6 transmission |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
That happened to me in my old TD6, same sound/symptons, was the TC and was repaired under warranty (many years ago). Birch know their stuff so I am sure Stuart will sort you out |
Springer Member Since: 15 Nov 2017 Location: Merseyside Posts: 104 ![]() ![]() ![]() |
Hi let us know how you get on at Birch Motors may be needing them soon myself (price etc)
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
So the diagnosis is in (box in bits). Basically the gearbox ECU has had a brain fart, told the gearbox to go into engine braking mode as I was accelerating up through the gears. As you can imagine, this is a bad thing. 2004 Vogue TD6 - Remapped |
So this happens 2004 Vogue TD6 - Remapped |
Ok so the image upload doesn't work on mobile! 2004 Vogue TD6 - Remapped |
Ok so an update on all this.
