Home > Technical (L322) > Question about in car telephone
speedymarktd6
if youve got wiring and buttons id suggest maybe find a scrap car and have the bit from under the armrest for yours and if you want you can try my cradle with phone in yours if it works get a cradle of ebay £50+ is about right hope this helps Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #3702 11th Mar 2009 8:41pm
Andy
Thanks for that kind offer- I'll bear that in mind.
Where is the microphone located and is there likely to be pre-wiring in my car? Also, apart from all the gubbins under the armrest etc, isn't there a module located somewhere in the car and if so, what does it look like, so I can see if it's installed. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3704 11th Mar 2009 8:51pm
Larry
England 2006 Range Rover SE Td6 Java Black
Mine has the cubby box fitment (but no phone cradle) fitted, but also has a separate speaker in the passenger footwell and mic on the A post. The speaker and mic seem to be add ons (had the exact same kit with a Nokia car kit on another car). When I use the phone with Bluetooth, the sound goes through the stereo speakers, so the additional speaker seems to be redundant.
Anybody else got this setup (and why?) I think that the previous owner must have had a separate kit fitted (again, why?)
Post #3761 13th Mar 2009 11:28am
The microphone is located behind a small grille in the headlining by the sunroof switch. I believe the sound comes through the front door speakers. Discovery 4 HSE
Post #3770 13th Mar 2009 12:06pm
Andy
Just popped that little plastic trim out - no mic there Sad 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3827 14th Mar 2009 3:22pm
ambishop
2003 Range Rover HSE 4.4 V8 Chawton White
ALL Range Rovers based on the BMW system have the ability to have the BMW bluetooth phone system installed. No USA spec Range Rovers are prewired for phone, but all others are either prewired (or equipped) or not prewired.
this is the telephone system wiring plug in the RR
If there is a wiring harness connected to that plug the car is prewired or equipped. If not the RR is not prewired for phone.
Either way installing the bluetooth system is very easy. Check out this page for instructions using BMW parts and specially configured wiring harnesses for either configuration
http://www.roverupgrades.com/Rover_Bluetoo...tions.html
Post #4542 4th Apr 2009 11:19pm
dan_uk_1984
Did you ever get to a resolution or get bored of the constant spamming? Smile
I'd like the factory fit installed, but from what I undterstand even if the wiring is there the Phone Control Module isnt, this is the bit that integrates the Phonebook with the display and all the buttons etc. I may of course be wrong.
I currently have a CK-1W installed, but would really like the factory gear and to be able to read my texts whilst driving at 130 down the m-way (joke!) I'd be interested to hear how far you got.
Dan
Post #6776 7th Aug 2009 6:44pm
Vogue
the mic is in the roof console in mine
Post #6779 7th Aug 2009 8:38pm
