Home > In Car Electronics (L322) > 2005 touchscreen turns off
JonnyO
United Kingdom 2004 Range Rover Vogue 4.4 V8 Stornoway Grey
Used an iidtool for the first time today to clear down a load of errors and since then the touchscreen starts up with the car, radio comes on, runs for 5 seconds or so then turns off. No lights on the unit and can’t be turned back in again unless you restart the car (same thing happens again).
Any ideas?
Post #528361 17th Sep 2019 5:38pm
JonnyO
No one seen this before? I’ve just seen it flash up A/V off when it went off if that helps at all?
Post #528549 19th Sep 2019 4:33pm
JCW
Check all the fibre optic connections to the various modules in the left rear compartment - I had similar symptoms and discovered one connection wasn’t secure.
Post #528550 19th Sep 2019 4:53pm
JonnyO
To close this off. This sprung back into life after unplugging the battery for a while and plugging in back in again.
Post #564850 17th Aug 2020 8:42pm
