Home > Technical (L322) > Advice Please!
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
I Also cme across this post.
https://www.fullfatrr.com/forum/topic35977.html
Posibillty its this also? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #528420 18th Sep 2019 11:23am
rjff
There's a good possibility that link may be your leak. It seems to occur on many TDV8s and no doubt ours will some time too.
Just above that connection and slightly forward is the oil cooler in the engine V and that is a known leak area. Plenty of info on this if you search. Eliminate these two and then look further if your clean up starts to show signs of getting oil back in the earea you're concerned about.
I don't know if Joe90 is a mechanic, but he ceertainly has done many of the jobs one needs to do on a Fatty. Have a look at his threads and Wiki entries Bow down Cheers
Richard
Gap IIDBT
Post #528421 18th Sep 2019 11:36am
