Home > Technical (L322) > ignition key sync
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
ignition key sync
I have 2 keys for my 2007 L322 (TDV8)
one of them was not working. when I successfully recoded it the other one stopped working. Each time I recoded one the other stopped working any help or advice
Post #527817 12th Sep 2019 3:56pm
try this,
https://www.fullfatrr.com/forum/topic47293.html ... - .- -.
Post #527818 12th Sep 2019 3:59pm
Weegie
To synch the keys
1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize.
Between stages 2 and 3 above DO NOT put the additional key in the ignition (stage 1) as this starts the whole process again. John
GAP iiD BT
Post #527838 12th Sep 2019 6:17pm
Pat
Thanks worked a treat
Post #528523 19th Sep 2019 10:46am
