Home > My Range Rover > 327,700 Miles - My First Range Rover |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3109 |
I was talking to a friend of mine earlier and mileage on Range Rover's came up and I mentioned your car as I recalled seeing it on eBay.
8th Jun 2020 8:24pm |
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 |
Hi Dhallworth, you asked about my L322 "is it still performing well after you had your teething issues sorted?".
8th Jun 2020 9:04pm |
Quick update.
20th Jan 2021 8:16pm |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 |
Thats dedication and certainly a fair bill, was the rear shocks and brake lines the major of the jobs or were there other large jobs to bring the bill up. |
20th Jan 2021 9:39pm |
Hopefully you'll get a chance to get some miles on her and enjoy her a bit this year Once you do that, you'll forget about the big bill!
20th Jan 2021 9:46pm |
Replacing all the metal brake pipes (flexibles done last year) was the fat end of £1k as were the four tyres (with alignment), shocks £890, front discs/pads £710 it soon mounts up alright! To be fair the; front disc/pads, rear shocks and two of the tyres could have waited a bit but would have gone down as advisories on this year's MoT. Interestingly the 2018 MoT had an advisory on the rear shocks "oil misting" but the July 2019 MoT (just before I purchased) was clean with no advisories. I guess they wiped the oil off the shocks before putting it in for it's pre-sale MoT. Since purchasing in September 2019 Big Blue has had 2x JLR main dealer services and all resultant health check items done (by the local independent). So I guess the engine and/or gearbox must be about due to cause grief. 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
20th Jan 2021 10:50pm |
Certainly does add up.
20th Jan 2021 11:07pm |
I did not get any service paperwork with the car other than a fully stamped service book (all from JLR main dealerships). So I can only assume the gearbox oil changes have been done as recommended by JLR.
21st Jan 2021 9:29am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
I would have challenged the advisor on ‘shock oil misted’, this is quite normal, a failure is either failing the bounce check or oil dripping... I hate MOT testers thinking outside the manual... the manual has been written and revised over decades to detail exactly how to test each component, what is a failure, what is an advisory or what is a pass, there is no grey area, no making it up, no ‘being helpful’, no ‘being safe’..... it’s either in the manual as a pass, failure, or advisory, if not it doesn’t go on the official paperwork... if they want to comment on the invoice to be ‘helpful’ that’s fine but not on the system.
21st Jan 2021 11:10am |
11th May 2021 5:15pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
neat matching clock adjustment Cheers, Greg
11th May 2021 10:19pm |
I did also take a real timed shot. 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
12th May 2021 8:43am |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
Well done!
12th May 2021 9:14am |
You would have thought wouldn't you? But no, JLR Reading do not have the details on their system. As you will see at the start of this thread, I purchased this car after seeing it reviewed in Land Rover Monthly. They called the dealership that sold and serviced the car until I got it. But were told they could not release any info on the servicing due to GDPR. A load of rubbish (I know because GDPR compliance was part of my job!) but that is what they told the Journalist. I intended to drive over to them to see what I could find out, but by the time my chemotherapy finished early 2020, Covid 19 restriction put a stop to that plan! However I may drive over is a month or so and see what I can discover. 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
12th May 2021 9:31am |
