Home > Technical (L322) > HVAC always warm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1752 |
An AC gas leak |
8th Sep 2019 6:28pm |
JonnyO Member Since: 01 Sep 2019 Location: Loughborough Posts: 28 |
If that was the case, wouldn’t I expect the air to be just at ambient temperature, not heated up? |
8th Sep 2019 8:03pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 732 |
Has it got LPG fitted?
8th Sep 2019 11:33pm |
Nope. No LPG. 100% standard |
9th Sep 2019 6:05am |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 |
As Mikey says I'd check the air con is gassed. If thats OK and holding the pressure I would suspect the compressor is stuffed. If you can check the live values and fault codes that would confirm. Also try selecting the max air con button if that doesn't make any difference at all then that's your most likely cause. When my compressor died the fatty was blowing very warm all the time no matter what setting just like yours and got so bad we were driving with the windows open just to get some cool air in. Trip to the garage me thinks |
9th Sep 2019 8:26pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
Most likely cause is this I had it on mine drivers side was all ways hot
9th Sep 2019 11:02pm |
I was wondering if it might be that valve.
10th Sep 2019 8:50am |
Oddly the HVAC started working again bit after this. Now the car is sold so I never did get to the bottom of this. |
17th Aug 2020 8:44pm |
