Home > Maintenance & Mods (L322) > 4.4tdV8 syphon oil change step by step.
Baltic Blue
I have been asked for a simple guide to follow when doing an oil and filter change on a 4.4 tdV8 using a syphon pump.
Hope this helps.
PS
Don’t forget to reset the service indicator if you have an iid.
Post #526743 1st Sep 2019 1:52pm
in words....
Warm engine up to thin the oil for a few minutes.
Open bonnet and remove black engine cover.
Remove oil filler cap.
Remove Black plastic cap from suction tube.
Loosen the oil filter housing by a couple of turns (36mm) socket, but do not remove at this stage.
Connect suction pump to tube.
A couple of pumps and you will see dirty old oil starting to syphon out of engine and into tank.
Remove oil filter, being careful to catch any drips.
Watch tank filling to approx 9.5 litres of old dirty oil.
Wipe out and clean filter housing.
Remove old filter from plastic cover/ bowl and clean.
Remove old rubber sealing ring from filter bowl
Lightly oil new rubber sealing ring and replace as per original.
Insert new filter in housing bowl/cover.
When all old oil has finished draining, re- fit filter and tighten to 27 nm torque.
Remove tank suction pipe from engine tube and replace cap.
Pour in 5 litres of new oil, then add 3 more measured litres.
Allow time for new oil to settle then start engine and check to ensure no leaks around filter bowl.
Stop engine and check oil level on dash display... it may be necessary to reset if it says Not Available, using a double click on the cruise control reset switch.
Top up as required by adding 0.25 litre of new oil.
Empty old oil from tank by pouring into empty 5litre containers.
Re check engine oil level on gauge, wait then top up 0.25 litre if required.
Replace black engine cover.
Reset the service indicator if you have an iid .
Post #526747 1st Sep 2019 2:47pm
Baltic Blue
Thanks Joe, much easier to read Thumbs Up
And In pictures...
Post #526749 1st Sep 2019 3:06pm
