![]() | Home > In Car Electronics (L405) > Where's my satnav gone? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
i would do a battery disconnection first ..hopefully this will reboot the systems.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
As Stan says... First thing to do sir |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
Thanks for the replies. I assume disconnecting the battery will affect pretty much all current user settings including seat positions, vehicle setup etc. or is this held in some sort of memory ? |
No sir, you will loose dash memory so, MPG etc + radar cruise settings etc but all seat memories are held in memoried ECU’s so won’t be affected...
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
How unusual a JLR satnav getting lost, have you tried showing it a Tomtom. letters not necessarily in the right order |
Disconnected the negative battery terminal and left for a while before re-connecting......no luck. It seems the features not working are sat nav, voice command and stored cd's. Unless I've missed something all else appears ok |
