Home > Technical (L322) > central jacking point
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Hey guys could someone tell me is there a central jack point for a trolley jack at the front of the car?
If so where do i put the axle stands?
I found this ... but never know weather to trust them?
https://workshop-manuals.com/landrover/l32...g/lifting/ Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #525574 20th Aug 2019 7:33pm
My car has certainly been jacked up a few times using the point shown in the workshop manual, to date without issue.
I always axle stands in conjunction with the jack. Thumbs Up
Post #525575 20th Aug 2019 7:42pm
dazza1983
the thing is lol, i cant figure out what this point is the workshop manual refers too? i had a look underneath and all i see is undertray lol
Pics upside down for some reason ??
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #525576 20th Aug 2019 7:46pm
The reason I can use it so readily is that my car doesn't have the rearmost cover as you seem to have. Don't ask me why it isn't there, I have no idea. Can't say I have missed it, in fact I can't see what its purpose would be, nothing there to protect.
The result is I can see the centre of the front subframe cross member quiet easily.
On your picture the front cross member is probably located where the central bolt head is, in the recessed area.
You should be able to find it by tapping, it's very solid.
Post #525580 20th Aug 2019 8:19pm
dazza1983
Is it this recessed point here?
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #525584 20th Aug 2019 8:55pm
I think that is where it should be. You could always drop the cover to check and then throw it away. Very Happy
Post #525585 20th Aug 2019 9:10pm
dazza1983
Anyone offer any more insight into this please?
Confirm that my circled pic is ok to lift on? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #525674 21st Aug 2019 12:55pm
nino_nino
here you go dazza1983,
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #525736 21st Aug 2019 5:39pm
DrRob
Tray off defo
Don’t jack on the red arrow Rolling with laughter Rolling with laughter
There is a diagram in the workshop manual somewhere Thumbs Up
https://www.fullfatrr.com/gallery/albums/u...manual.zip
Download to your PC and I’m sure there is a lifting or jacking document Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #525742 21st Aug 2019 5:41pm
nino_nino
Or green.
Rolling with laughter Rolling with laughter 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #525745 21st Aug 2019 6:25pm
dazza1983
Thanks guys.
So tray off and I’m guessing you jack on one of these horizontal bars?
Does it matter if it’s the one closet to the front of the car or the rear of the car?
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #525820 22nd Aug 2019 9:34am
DrRob
Check the document on jacking/lifting in the workshop manual that you can download from the wiki Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #525821 22nd Aug 2019 9:47am
I thought there was a subframe jacking point at the front of the engine below radiator/condensor. Much better for lifting less weight. (Obviously I can no longer have a look or take a pic Confused ) .
Post #525824 22nd Aug 2019 9:55am
dazza1983
Hey DrRob. I don’t know if I’m being thick but I’ve looked at the document numerous times and I even linked it above in my 1st post. However the picture illustration is terrible and if you can match it to a real life picture your better than me mate lol. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #525827 22nd Aug 2019 10:13am
ur20v
A Trap
I have got to say this is the worst forum for unhelpful “do a search” comments I have ever been on, I understand the long timers here have seen it all before many times but posting do a search means that there are loads of threads coming up in the search’s with no information, just do a search comments!! I suggest either answer the question or don’t read the thread or post if you cannot be bothered to be helpful. Most of the time it would take as long and the same amount of typing to answer as to direct elsewhere or “ do a search”
This should be a helpful brotherhood of tormented ff owners not entitled police state unhelpful members!
Rant over.. for now.
Post #525830 22nd Aug 2019 10:51am
